gideonh
Jan 04, 2023Aspirant
Circle no longer working
Hello All...Happy new year... My circle app is no longer allowing me to access my router, previously it was just not sending me the admin passcode, I followed advise from the forum and deleted th...
Jan 04, 2023Guru - Experienced User
What FW version is on the orbi system?
Might review this as well:
May need to update to New SPC instead of older Circle gen...
What version of Orbi app are you using?
- gideonhJan 04, 2023Aspirant
Hi There,
thank you for your comments, I am currently running V2.7.3.22 on the orbi... app version is 2.21.1.353.
I have tried al of what you have suggested and now the app is not even recognising the router as a compatible circle device, so currently have absolutely n way of connecting to the orbi using circle, despite restarting the router, rebooting he router, uninstalling and reinstalling circle.
Are you suggesting the course of action is to ditch circle completely and go with SPC?
G
- FURRYe38Jan 04, 2023Guru - Experienced User
Might update FW since your behind:
I'd factory reset and setup from scratch after wards. Be sure to update the RBS FIRST, then RBR lastly.
okay, I'll try that now... for some reason the auto update wasn't seeing the new update... but have done that manually now... thank you for spotting that...
