gideonh
Jan 04, 2023Aspirant
Circle no longer working
Hello All...Happy new year... My circle app is no longer allowing me to access my router, previously it was just not sending me the admin passcode, I followed advise from the forum and deleted th...
gideonh
Jan 05, 2023Aspirant
Problem has now been resolved, thank you, it looks like it was the update that was needed to solve the issue, thank you for your help...
Gideon
Jan 07, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
