robertkat's avatar
robertkat
Follower
Jan 13, 2019
Circle not pausing my devices
I have Circle installed and I see the list of devices. When I hit the pause you can still access the internet. If I use Genie and select the same device and pause, it works. Any idea what is going on?
  • FURRYe38's avatar
    What FW is currently loaded?
    You might set up some reserved IP addresses ON the router for your devices first. Then enabled Circle and see.
    • DWost's avatar
      DWost
      Tutor
      This has been an ongoing issue on my network as well.  I'm not impressed with the Circle functionality at all.  It's very childish and extremely clumsy to set up.  I would love to see a more robust professional option be part of the framework.  With that being likely to not happen, here is the issue.  I have created a profile that has two devices assigned to it.  If my son is not online and bedtime hits, the pause feature works fine.  If he is online and playing a game and I try to shut him down it will not pause the device untill he is finished and shuts the device down.  From there if he tries to get back online it will be blocked but it doesn't shut him down immediately like I want.  I'm running the most current FW on all my satelites and the router and I've tried all suggestions of rebooting, deleting and readding profile, etc.. and it still doesn't work.  Any help would be greatly appreciated.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi DWost, welcome to the community! The issue of certain apps with active sessions not getting cut off when Bedtime kicks in has already been reported to engineering and will be worked on with the Circle team. As it stands, this is currently a limitation on the feature.
        Dexter
