RG-
Sep 04, 2020Follower
Circle on Netgear slows down your speed
After doing some testing I found out that when you enable circle(1st Gen Free App) on your R7900, I slows down speeds 50% and some cases could be 90%. When I had Circle enabled on my GB connection, I...
Bigfoot87
Sep 12, 2020Aspirant
I have see similar issues on RBR50 device. I updated from firmware 2.5.1.16 to 2.7.0.70. After doing so I was prompted to try parental controls in the orbi app. After enabling parental controls, there seemed to be massive speed issues and connectivity issues. There is no option to disable the parental controls in the orbi app. The only way I was able to disable was to reset settings. Now the orbi app is constantly prompting me to re-enable a feature and there is no way to dismiss the prompt unless I force close the app.
