Tibetan70
Apr 25, 2021Tutor
Circle or other parental control
Hi! I bought a non-cheap router! The R9000 X10! Netgear recently claimed to be the fastest router. Well, that's right. But! A very important feature is missing: parental control. My previous (cheap) ...
Apr 27, 2021Guru - Experienced User
Some NG products support Circle, some do not.
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
https://kb.netgear.com/000044718/Which-NETGEAR-routers-support-Circle-Smart-Parental-Controls
- Tibetan70Apr 27, 2021Tutor
Thank you so much for this answer, it was terribly helpful! So I have an immeasurably expensive router that I can throw away in the trash. Thanks! Is there anything you can know about how Netgear plans to handle parental controls after April 2021? Because there is no information about that.
- FURRYe38Apr 27, 2021Guru - Experienced User
NG has started this new forum and seems to be implementing there newer Smart Parental Controls on some of there router products:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Something to check into. Thought not sure if the R9000 series will be supported. We don't get that kind of future planning information here in the forums.
I would not throw the R9000 router in the trash, it still has good use. Though you may find someone to buy it. Or maybe see if 3rd party FW has any solutions that may help you out. Like DD-WRT or Voxel. OpenDNS maybe something to look into as well.
- svetaketuApr 27, 2021Luminary
Hi Tibetan70,
It seems that the R9000 is also not listed in the compatibility list for the standalone Circle hardware:
Adding Circle or SPC on the R9000 is probably slim since it has been out for several years now and most probably its already approaching end of life.
Probably better if you exchange your R9000 for a newer model and base your decision on the article provided by FURRYe38.
