svikas's avatar
svikas
Circle passcode lost due to phone change
I have Family Cirle Enabled on my Netgear Router, but when I upgreaded my phone from a iPhone 7plus to a iPhone 10, I seemingly locked myself out.  The passcoded resend doesn't work and I don't know the 4 digit # ?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi svikas, I have sent you a message. Please check your inbox.
    Dexter
  • I am also experiencing the same issue. What is the solution?
    • LlZoll's avatar
      LlZoll
      Having same issue. Cannot access anything anymore. This happened over night now my browser in my phone won’t even connect over WiFi and I’m not getting the admin text codes. Very frustrating
      • svikas's avatar
        svikas
        They can retrieve the code for you. Please start a new thread as this is resolved. They will send you a private message and once verified , they can send you the code.
