jwc-jwc-jwc
Jun 30, 2019Aspirant
Circle passcode reset Orbi RBR50
This seems to be a common request and the only way to get an answer is to have someone DM you. I have a new iPhone and cannot login to Circle. When I do the whole "I am the only admin" process I DO g...
misjas
Jan 13, 2020Tutor
I don't understand why 1,000 people have this question and nobody posts an answer? You log on to Circle and send a passcord for circle. It gets sent, then you enter it and it says "Could not connect". So I go into Orbi and try to toggle on the parental controls and it sends me to Orbi app. Around and around you go. Does anyone have a clue here?
Jan 13, 2020Guru - Experienced User
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Good Luck.
misjas wrote:I don't understand why 1,000 people have this question and nobody posts an answer? You log on to Circle and send a passcord for circle. It gets sent, then you enter it and it says "Could not connect". So I go into Orbi and try to toggle on the parental controls and it sends me to Orbi app. Around and around you go. Does anyone have a clue here?
