Peytonloki
Nov 17, 2020Tutor
Circle Premium no longer working
As of 11/12 Circle is no longer blocking websites based on settings. The visited and filtered history are also no longer populating. And off times are no longer respected.
Christian_R
Nov 24, 2020NETGEAR Employee Retired
Hello Peytonloki,
May you power cycle your router and reinstall the Circle app.
Thanks,
Christian
- PeytonlokiNov 24, 2020Tutor
Thanks for the reply Christian. I've done both of those things, as well as taken updates on router as well.
- Christian_RNov 25, 2020NETGEAR Employee Retired
Hi Peytonloki,
May you factory reset your router by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Orbi app.
Christian
- PeytonlokiNov 25, 2020TutorThat was also already done as well.
