Peytonloki
Nov 17, 2020Tutor
Circle Premium no longer working
As of 11/12 Circle is no longer blocking websites based on settings. The visited and filtered history are also no longer populating. And off times are no longer respected.
Christian_R
Nov 24, 2020NETGEAR Employee Retired
Hello Peytonloki,
May you power cycle your router and reinstall the Circle app.
Thanks,
Christian
Peytonloki
Nov 24, 2020Tutor
Thanks for the reply Christian. I've done both of those things, as well as taken updates on router as well.
- Christian_RNov 25, 2020NETGEAR Employee Retired
Hi Peytonloki,
May you factory reset your router by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Orbi app.
Christian
- PeytonlokiNov 25, 2020TutorThat was also already done as well.
- Christian_RNov 27, 2020NETGEAR Employee Retired
Hello Peytonloki,
Thanks for confirming. I would recommend using the following link to open a support case regarding Circle: https://www.netgear.com/support/contact.aspx. To open a support case, please follow the steps below.
1. Select "Get help on my NETGEAR product"
2. Select your country
3. Select "I have a NETGEAR product without a serial number"
4. In the dropdown menu, please select "Circle" as the product
Christian
