Peytonloki
Nov 17, 2020Tutor
Circle Premium no longer working
As of 11/12 Circle is no longer blocking websites based on settings. The visited and filtered history are also no longer populating. And off times are no longer respected.
Christian_R
Nov 25, 2020NETGEAR Employee Retired
Hi Peytonloki,
May you factory reset your router by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Orbi app.
Christian
Peytonloki
Nov 25, 2020Tutor
That was also already done as well.
- Christian_RNov 27, 2020NETGEAR Employee Retired
Hello Peytonloki,
Thanks for confirming. I would recommend using the following link to open a support case regarding Circle: https://www.netgear.com/support/contact.aspx. To open a support case, please follow the steps below.
1. Select "Get help on my NETGEAR product"
2. Select your country
3. Select "I have a NETGEAR product without a serial number"
4. In the dropdown menu, please select "Circle" as the product
Christian
- PeytonlokiNov 27, 2020TutorWhen I do that, I receive the following:
Based on your serial number and purchase date, NETGEAR can offer you the following support options
I can’t open a ticket without paying for support. This doesn’t appear to be an issue limited to my experience, since I’m seeing multiple reports of Circle Premium features not working by various users.- Christian_RDec 03, 2020NETGEAR Employee Retired
Hi Peytonloki,
May you send me a private message with the following info and I'll have it forwarded it to support.
Name:
Email:
Phone:
Preferred Contact Time:
Router Model:
Router Firmware Version:
Thanks,
Christian
