PSUHammer
Mar 24, 2020Luminary
Circle seems to be randomly killing Internet ingress/egress from my Orbi starting this week
I have an RBR50 with two satellites. I have had Circle enabled for a number of months now with little issue. We actually use it quite a bit to limit electronics time for the kids. Starting this...
- Sep 08, 2020
Hubba_Bubba wrote:Activated Circle last evening on my RBR50 and RBS50 satellite after updating the firmware to the .32 version. So far, so good. No issues that I've yet to see.
Happy to confirm that two months later, that Disney Circle is operating just fine. No problems.
Retired_Member
Apr 05, 2020Finally I decided not to perform the firmware downgrade and telnet to disable firmware upgrade after reading all the firmware release notes, there are a number of security update that has been added for almost each firmware upgrade.
I had to give Circle a miss for now until there's a firmware that is stable with Circle.
PSUHammer
Apr 06, 2020Luminary
I am canceling my Circle service until this mess is straightened out. Netgear support is awful. What is it with companies sucking with support these days? Almost all of them! Almost every retail consumer facing tech company has crappy support. Even the basics like communication over social media. Awful.
How can a breaking change make it into production firmware? Testing failure internally. Bad change management. Bad software review and release processes.
- Retired_MemberApr 07, 2020
Hi PSUHAmmer, you should proceed to cancel the Circle subscription as there isn't any proper support provided by the Netgear Support and Circle Support to resolve the known issue. In fact, no one should pay for a feature or product that does not work as it should / described.
Take a look at how the moderator reply to our question and the Netgear paid support works the same, not solving the problem or answer the question directly to resolve the problem.
- Christian_RApr 08, 2020NETGEAR Employee Retired
Hello Community,
Our product teams are currently looking into the reports of Circle and Orbi. We currently do not have an ETA on the next firmware version or any further details at this moment.
Thank you for your patience,
Christian
- Hubba_BubbaApr 08, 2020Star
Whatever, man. When your support is contacted to discuss the issue over and over, it's not "these reports". It's a "known issue". Just at least acknowledge that it exists, you know about it and have determined that it can't be resolved without a firmware fix, and to save countless people (other than the ones here), post it on your website and Facebook so others don't spend countless hours trying to fix something that's not fixable without a firmware update. THAT is what customer service should do. Otherwise, you're going to continue getting slammed here and in social media. I'm sure that the owners of Circle would appreciate you acknowledging and fixing this, too, as it drags down their status in the process.
