PSUHammer
Mar 24, 2020Luminary
Circle seems to be randomly killing Internet ingress/egress from my Orbi starting this week
I have an RBR50 with two satellites. I have had Circle enabled for a number of months now with little issue. We actually use it quite a bit to limit electronics time for the kids. Starting this...
- Sep 08, 2020
Hubba_Bubba wrote:Activated Circle last evening on my RBR50 and RBS50 satellite after updating the firmware to the .32 version. So far, so good. No issues that I've yet to see.
Happy to confirm that two months later, that Disney Circle is operating just fine. No problems.
Smge1lc
Jul 16, 2020Guide
I'm glad you guys are getting some reprieve, but last night I updated to .32 and enabled circle.
Today, everyone in the household is complaining about wifi drops and google home and alexa are in and out.
I just shut off circle again, so I hope that will bring back some normality. Overall, the system was relatively stable at .16 with circle turned off.
Hubba_Bubba
Jul 17, 2020Star
Smge1lc wrote:I'm glad you guys are getting some reprieve, but last night I updated to .32 and enabled circle.
Do you use a satellite, and if so, did you update it seperately and first? Just as an FYI, are you using a modem or a gateway? If you are using a gateway, you can check to see if you have a dual NAT situation by using a Command Prompt, and typing "tracert 8.8.8.8". If the first two IP addresses are local private address, not public addresses, then you do. This can cause you to have problems. See if you can put the ISP’s gateway into bridge or passthrough mode. This will disable the gateway’s NAT, firewall, and DHCP functions and reduce it to a simple internet modem. Many gateways offer these settings, but not all. Log into the web-based GUI of the gateway and check for a NAT, passthrough, or bridge mode setting, but keep in mind that sometimes it’s hidden. If you don’t see it, search the internet for details on your particular model, or call your ISP’s tech support.
- PSUHammerJul 17, 2020Luminary
I installed .32 a few days ago and can confirm Circle appears to be stable again....
