9re990's avatar
9re990
Circle setup endless loop
I am attempting to setup Circle on my router.
Router is R6400v2 (Nighthawk AC1750) with firmware V1.0.2.60_10.0.44.
(The dropdown menu does not provide this option)
Circle is enabled on the router under the Parental Controls tab.
Agent Version: 2.0.8.9
App Database Version: 1.3.1
I am using the Circle iOS app to complete setup:
iOS v 11.4.1
Circle App v 2.0.17
I get as far as the Enable Circle section and it endlessly loops.
This appears to be the same issue in this thread.
https://community.netgear.com/t5/Orbi/Orbi-Circle-setup-loops-in-app/m-p/1491252
In this thread, the user did nothing and the issue resolved itself on Jan 23, 2018.
I have recreated the same steps as above user (doing nothing until Jan 23, 2018) yet my issue still persists.  Please advise.
  • Hi 9re990,
    I have sent you a message. Please check your inbox.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi 9re990,
    Dexter
    Community Team
    • Kasra's avatar
      Kasra
      I do have same issue on Orbi AC3000 (RBR50).
    • Kasra's avatar
      Kasra
