gekoenig
Aug 15, 2021Aspirant
Circle Setup with R6700
I am trying to set up Circle for the first time, I installed the Android app for the inital install, it is asking me to scan the QR code on the bottom of the router and/or enter a 17 digit code. My r...
gekoenig
Aug 16, 2021Aspirant
I figured it out, there are 2 Circle apps, Circle 1st gen worked out for me.
Aug 16, 2021Guru - Experienced User
I believe the router is using the newer SPC controls which use the newer Circle 1st Gen:
https://community.netgear.com/t5/NETGEAR-Smart-Home-Parental/bd-p/en-home-smart-parental-controls
Something to keep in mind.
