cemtp
Jan 11, 2019Aspirant
Circle shows zero internet usage
I have been running Circle app on Orbi for quite some time.
Recently it started to show no internet usage. I only see "No usage to report for this period".
I deleted the app and reinstalled ...
- Jan 16, 2019
DexterJB
Jan 16, 2019NETGEAR Moderator
- DexterJBJan 21, 2019NETGEAR Moderator
Hi cemtp,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- cemtpFeb 03, 2019Aspirant
Thanks for following up.
Suggestions in the link didn't help so I cancelled my subscription.
Not an ideal solution but the problem is solved now :(
Cem
