cemtp
Jan 11, 2019Aspirant
Circle shows zero internet usage
I have been running Circle app on Orbi for quite some time.
Recently it started to show no internet usage. I only see "No usage to report for this period".
I deleted the app and reinstalled ...
- Jan 16, 2019
DexterJB
Jan 21, 2019NETGEAR Moderator
Hi cemtp,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
cemtp
Feb 03, 2019Aspirant
Thanks for following up.
Suggestions in the link didn't help so I cancelled my subscription.
Not an ideal solution but the problem is solved now :(
Cem
