doug0312
Mar 03, 2021Guide
Circle will not work with Nighthawk R7000P
I just purchased a Nighthawk R7000P router specifically to use the Circle features to manage kids devices. does this even work? it seems like it's DOA out of the box. The Circle will not configure....
Mar 03, 2021Guru - Experienced User
what actual comcast modem is it?
If its on the 10.0.0.1 and your only manually setting the netgear to the next ip address, but both still have dhcp running, you're in a double nat.
What is Double NAT? | Answer | NETGEAR Support
did you disable the router on the comcast device? (hint, shutting off wifi doesn't disable its routing functions)
doug0312
Mar 03, 2021Guide
thanks
- the Comcast model is an X B6-T. It's their default gigabit modem/router at least here in the SF bay area.
I will work on flipping the Comcast router to Bridge mode this evening and see if that gets it running!
- doug0312Mar 03, 2021Guide
Okay, I enabled bridge mode on Comcast modem, which disabled its integrated Router
And, i restored the default IP on the Nighthawk to 10.0.0.1 thereby I believe eradicating the "rat's nest"
now the setup is:
Internet > Comcast modem (no router) > Nighthawk as router and DHCP server > iMac (ethernet0
and I've also connected my iPhone running iOS 14.4
Result: exactly the same outcome. Parental controls pops up a circle page on my iPhone that says "Darn, couldn't find Circle on your router"
- plemansMar 03, 2021Guru - Experienced User
- Christian_RMar 04, 2021NETGEAR Employee Retired
Hi doug0312,
I'd like to follow up and ask if you were able to resolve your issue or get in contact with our support team for assistance with setting up Circle on your R7000.
Christian
