SilverWinterSky
Mar 27, 2021Aspirant
Circle002 certificate issue
My sons Macbook is suddenly unuseable on our Orbi wireless network, showing the dreaded “This connection is not private” error on all browsers. The associated certificate is Circle002. I’ve trie...
Christian_R
Mar 30, 2021NETGEAR Employee Retired
Hello SilverWinterSky,
May you forget the WiFi network on your son's Macbook and reconnect to the network.
Christian
SilverWinterSky
Mar 30, 2021Aspirant
Thank you. I will try what you suggest.
Can you explain why it might help?
- Christian_RMar 31, 2021NETGEAR Employee Retired
This is to help isolate the root cause of the issue you're experiencing since the Macbook seems to be the only device you're having issues with.
Christian
