inteller
Jan 19, 2019Apprentice
Data drops with Circle enabled on Orbi
When I enabled Circle and moved certain constant data devices as "unmanaged" these devices continue to drop data. Unmanged devices should have no filtering or restrictions through Circle. One impor...
Jeremyinsf
I've been complaining about that since the current version (and the beta before that) was released. I do not have this problem on previous versions (If I revert, it works fine) - it's something new as the last major release.
It seems to be an issue with how DNS is redirected, and name resolution 'pauses' (and then times out) when it's enabled.
When I reported this before the response was to ask me "what websites are you having problems with" - which, missed the point completely. It's not about specific websites. It's a foundational problem.
- intellerJan 19, 2019ApprenticeSo it used to work and they broke it? FML.
- JeremyinsfJan 20, 2019Apprentice
Yes.
Or, things changed in a (orbi) new version and they didn't update the embedded Circle (it has remained at the same version) and this broke it.
But, yes. And I reported it in the beta and they proceeded anyway with a forced rollout production version and did not fix it. And I hI have no idea if it will be fixed in the next version.
inteller wrote:
So it used to work and they broke it? FML.- intellerJan 20, 2019ApprenticeNone of this surprises me....garbage.
