inteller
Jan 19, 2019Apprentice
Data drops with Circle enabled on Orbi
When I enabled Circle and moved certain constant data devices as "unmanaged" these devices continue to drop data. Unmanged devices should have no filtering or restrictions through Circle. One impor...
inteller
So it used to work and they broke it? FML.
Jeremyinsf
Jan 20, 2019Apprentice
Yes.
Or, things changed in a (orbi) new version and they didn't update the embedded Circle (it has remained at the same version) and this broke it.
But, yes. And I reported it in the beta and they proceeded anyway with a forced rollout production version and did not fix it. And I hI have no idea if it will be fixed in the next version.
