inteller
Jan 19, 2019Apprentice
Data drops with Circle enabled on Orbi
When I enabled Circle and moved certain constant data devices as "unmanaged" these devices continue to drop data. Unmanged devices should have no filtering or restrictions through Circle. One impor...
inteller
Apr 30, 2019Apprentice
AAAAAAND.....still not fixed with 2.3.1.48...
Zacks
May 01, 2019Aspirant
I. Also experiencing this issue. I have firmware 23148. I turned off circle and still have the issue. Do I also need to reboot or go through a new setup to completely disable?
- The_CurlyMay 06, 2019Aspirant
I have the same issue when Circle is enabled.Without Circle, no dropping of the wifi anymore. Although it works as a temperary workaround, this is not a fix!
- intellerMay 06, 2019ApprenticeIt isnt dropping wifi, it is dropping requests that unmanaged devices are trying to make.
And STOP messaging me netgear! I WILL NOT be your product tester/fixer! I PAY you to figure these things out! Fix this junk! - The_CurlyMay 06, 2019Aspirant
It is happening for both managed and unmanaged devices for me, not sure what it is doing but no device can access the internet anymore when the issue occurs. It does restore after some minutes.
