finny23j's avatar
finny23j
Device having issues with Circle enabled
Hi all,
I have enabled Circle on my Orbi. I am running into a single specific issue with the Google Pixel 3.
It started holding on to the bedtime schedule. So I removed the device from circle. When we reconnect the device to the Orbi, it does not show up and also it does not get added back in to the Circle as a device.
Any one have a thoughts on this, or should I do a factory reset of the Circle settings on the Orbi to see if this resolves it?
Thanks in advance
Running the latest firmware
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi finny23j,
    Our engineering team is aware of Circle causing issues when enabled. We currently do not have an ETA on a fix. In the meantime, you may disable Circle as a workaround.
    Christian
