rickcr1205
Jun 21, 2023Follower
Device shows up and says "paused" but device is NOT paused (orbi rbr750)
Hardware RBR750
Firmware V4.6.14.3_2.3.12
I've rebooted the orbi multiple times and yet, for some reason, the parental controls stopped working - that is, no matter what I try to 'pause' the internet simply does not pause - whether I pause an individual device, a profile, or the entire system, pause is simply not working.
Any suggestions? It's frustrating, since I paid up for a full year and it stopped working.
1 Reply
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
