arushol78
Nov 12, 2020Follower
Disable Circle first generation on Netgear
My Circle First Gen is no longer working so I purchased a Circle Home Plus and am trying to work through the set-up config; however, it keeps saying that "circle home" is still enabled. I cannot disable Circle 1st Gen on the Netgear.
1 Reply
- Christian_RNETGEAR Employee Retired
Hello arushol78,
The articles below may help you disable Circle. To disable you may perform the same steps as enabling.
Christian
