orbi-customer's avatar
Jul 07, 2020
Disable Circle
Orbi worked great until we started using Circle. Wifi now stops at least once a week. I have to reboot everything. ONT, Router, etc. about 1/week. I have read that some people disable/enable Circle from the app.
Can you direct me to the instructions?
Also, is there an app out there that works properly?
  • I figured out how to disable Parental Controls in settings.
    Then this morning - printer was not visible to computer so I disabled Circle, rebooted computer and printer, to no avail.
    I looked at Armor Settings and turned that off and printer seems to be back. Issue might be Armor.
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hi orbi-customer,
      Thanks for reporting this and updating your thread.
      Christian
