EPCG
Dec 17, 2020Follower
Disney Circle blocking certain sites
I see many are having issues with Circle now. It was working great for the past year, up to about 3 weeks ago. Certain sites/services are blocked unless the filtering is turned completely off. I can ...
Christian_R
Dec 22, 2020NETGEAR Employee Retired
Hello,
I would recommend using the following link to open a support case regarding Circle: https://www.netgear.com/support/contact.aspx. To open a support case, please follow the steps below.
1. Select "Get help on my NETGEAR product"
2. Select your country
3. Select "I have a NETGEAR product without a serial number"
4. In the dropdown menu, please select "Circle" as the product
Christian
