jrwilson88
Oct 22, 2017Aspirant
Disney circle enabled on router but circle app not finding
I enabled Disney circle on my router, but when I go to the circle app it says it can't find circle on my router.
- Oct 24, 2017
Welcome to the community, jrwilson88
Have you tried rebooting the router?
Make sure that your app is connected to the router as well.
ElaineM
Oct 24, 2017NETGEAR Employee Retired
jrwilson88
Oct 27, 2017Aspirant
Thank you that worked!
- ElaineMOct 30, 2017NETGEAR Employee Retired
You're welcome and thank you for the update.
Glad that it worked!
Have a great day.
- rgahan0854Nov 13, 2017Aspirant
I am unable to find the circle device on my phone. I have the most current update for the router and the app. I had to reset the app because it was causing issues, before that it found my router just fine. I have the circle control enabled on the netgear admin page and I restarted it, but I still get the message that the app can't find my router.
- DexterJBNov 14, 2017NETGEAR Moderator
