VincentNguyenQu
Apr 24, 2018Star
Disney circle keeps disconnecting on R7000
Good morning, A few months ago Netgear included a new feature in the R7000, namely Disney Circle. Out of curiosity I enabled it, and despite some flaws in design, I find it very practical. Un...
bytheriver
Oct 05, 2018Initiate
Same thing here. It's too bad because when it works, it works well. But having to reset everything more and more frequently is making look for other routers and parental controls.
Bluestuff
Oct 07, 2018Aspirant
AC1900 same thing here, after any reboot it's disabled. Quite annoying and a showstopper when not at home, as no way to remote enable...
- sammer4uOct 11, 2018Aspirant
I have the same issue. Worked well for 2 weeks and now it continues to lose connection. Very VERY annoying and disturbing!
Any help and assistance is welcome!
- martynzOct 11, 2018Star
Pretty slack , I have voiced my last good bye to Netgear here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/I-will-Never-buy-another-Netgear/m-p/1650744#M107228
- MulletriverNov 05, 2018Aspirant
I'm having the same problem. My setup is also double Nat'd, as the setup instructions suggest. I've got the router plugged into my cable modem (Telstra).
