chris_v
Oct 09, 2019Tutor
Enabling Circle breaks Orbi
I am running the latest firmware, V2.3.5.30 and over time our network became almost unusable. I finally decided to spend a day debugging the issue and have discovered that it was Circle causing the p...
DexterJB
Oct 11, 2019NETGEAR Moderator
- treadpoolNov 09, 2019Tutor
Can you share the message? It might help others...
- blaineeousApr 14, 2020Aspirant
Netgear. This is very frustrating. This is one of the main reasons I bought this product. What is being done to resolve this issue? Transparency is important to us as customers.
- elddumMay 11, 2020Aspirant
I have the exact same issue.
Just bought the Orbi - selected with the specific purpose of the parental controls and they don't work!
I thought that firmware V2.3.5.30 was the latest (according to the inbuilt firware check it is) - but apparently the latest is V2.5.1.16. Does anyone have experience if this hanging from using Circle is fixed in this release (2.5.1.16)?
If not, its back for a refund!
Thanks!
