RogerBenson
Jun 02, 2019Aspirant
Fine tuning Circl Timer Feature
I've set a profile up for my son's devices and put a 2 hour limit on internet usage, but after going to dinner I checked and all the time had been used up by system processes on his PC and iPad while...
DexterJB
Jun 03, 2019NETGEAR Moderator
RogerBenson
Jun 14, 2019Aspirant
Thanks, those are good ideas. Quick question, is there a way to easily identify the IP addresses and block or let pass unmanaged?
- DexterJBJun 19, 2019NETGEAR Moderator
Hi RogerBenson, some users do use Brightcloud linked below to check the IP's. Once you're able to identify the source of the IP, you can try adding the platform as described here or add a custom filter described here.
https://www.brightcloud.com/tools/url-ip-lookup.php
Dexter
