rockcrusher's avatar
Feb 24, 2022
Lost usage and history for circle premium on R6700v3
Lost all usage and history in my circle app. Explains why my kid is so tired, it is not logging his time on the computer so he has been able to far exceed the time he needs on his computer for stuff....
  • rockcrusher's avatar
    rockcrusher
    Mar 01, 2022
    I guess to close this thread I finally figured out that my circle premium membership had become disassociated with my account. So though it wasn't showing that i needed to upgrade to Premium it was not showing the premium account features.
    So after resetting circle, uninstalling the app and installing it again multiple times, rebooting my router, resetting my router, resetting circle, and finally getting in touch with netgear circle premium support (who directed me to call Circle, which was impossible with their number either disconnecting or showing a busy signal) i cancelled my circle account in google, deleted the app, turned of circle on the router, restarted the router, and then added circle back to my phone, restarted circle on the router, then after getting the app loaded it gave me the option of adding premium back to the account. I did so and within an hour I finally started to see history and usage stats showing back up.
    All tolled it was probably 5 hours of my time trying to find something that was probably an issue with the latest firmware update on my router or a backend problem with netgear and circle.
    Hope this helps someone in the future.
