em2394
Aug 04, 2021Tutor
Move on to Circle 2nd Generatiom
Hi, I bought the R7000p with Circle included in 2018 (I'm in UK). Worked well but seem to be having a variety of problems now with the Circle app and so I'm thinking of moving on to the 2nd generatio...
Aug 04, 2021Guru - Experienced User
What FW is loaded on the router?
Do you see parental controls on the routers web page anywhere that shows anything about Circle or Smart Parental Controls? Might be under Basic Tab or Advanced Tab/Advanced/Security?
em2394
Aug 04, 2021Tutor
Hi Thanks for responding.
FW v1.3.1.64. If I click on Check for Updates says No New Firmware us available at this time. Not sure that's correct ??? THink 1.3.3.140 is latest ?
I can see under Parental Control tab and just mentions Circle and then I can click on the 'Go To Circle' button which takes me to the app on my phone. Ist Generation that came with router on purchase in 2018
Thanks
- FURRYe38Aug 05, 2021Guru - Experienced User
Check NGs support page for what currnent version of FW is available.
