marcojr's avatar
marcojr
Tutor
Jan 12, 2021
My Circle is no longer working
I was using Circle for months with no issue. Suddenly it's stopped to work and wasn't blocking amything more.
So, I decided to reinstall and do everything from scratch. Now it's no longer listing my devices.
I am not sure but I believe that this stopped to work on the latest update of iOS.
Any suggestions ?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello marcojr,
    Have you had a moment to factory reset your NETGEAR router and run through the setup assistant again?
    Christian
  • My Circle is discontinued and you have to use the "Circle 1st Generation" instead.
  • Add me to the list of users looking for Circle app to be natively supported on an Orbi Router RBR850.   I would think a $700 product like this would have parental controls
