NoCircleNoGood
Aug 02, 2020Initiate
Need to add Circle to AX6000 / RBK850!!
I bought this with the expectation that Circle was included...bug mistake! Website is confusing IMHO. I can't believe this is not included at these prices...disappointed to say the least! Anyone h...
Jmauser33
Nov 19, 2020Tutor
Would love a little more information Cristian, Ideally, an indication of where mergers is with adding circle parents control support with this router. I just dropped $1k on this router package, specifically because i thought it worked with circle.
As fast as it is, i have to return this if the functionality isn’t showing up in the next few weeks.
PLSY
Dec 12, 2020Aspirant
Can anyone tell me when will be available Circie in RBK850. I have already waited for over 9 months about this.
- dtayDec 12, 2020Luminary
PLSY wrote:Can anyone tell me when will be available Circie in RBK850. I have already waited for over 9 months about this.
Same here but I have the standalone Circle Plus, which seems to work (for the most part) with AX6000 except for some performance degradation.
Interestingly, Circle has updated their router compatibility list with the following now:
⚠︎ Orbi RBR750, RBK752, and RBK753 (Only compatible with Circle Home Plus, Use Compatibility Mode if issues are seen)
⚠︎ Orbi RBR850/RBS850, RBK852, and RBK853 (Only compatible with Circle Home Plus, Use Compatibility Mode and fully update the router firmware if issues are seen)Prior to this update, their notes said it wasn't compatible and they were "investigating the issues."
