speedster99
Mar 21, 2020Aspirant
Nighthawk - Circle
Hi, Enabled Parental Controls on the router admin page. It directed me to install Circle 1st Gen app on Android which I complied with. The app says 'We found circle'. Clicked on Manage Circle. Chos...
Christian_R
Mar 24, 2020NETGEAR Employee Retired
Hello speedster99,
Welcome to the community! Were you able to setup a phone number on your Circle account for the passcode to be sent?
Thanks,
Christian
speedster99
Mar 24, 2020Aspirant
Hi Christian,
Firstly, thanks so much for your quick reply! Much appreciated.
It was while trying to set my "Circle 1st Generation" account using my Android phone that it was asking for the passcode.
Where can I do it?
How do I get the code?
Thanks again!
- Christian_RMar 24, 2020NETGEAR Employee Retired
Hi speedster99,
Happy to help! Please check out the article linked below on how to edit your account information.
Christian
- speedster99Mar 24, 2020Aspirant
Hi Christian,
On my Android Galaxy S10, I installed the Circle 1st Gen app. I don't see the menu though; the entire screen is occupied and no menu is visible.
I captured two screen recordings for you to debug easily.
The first one is I go to Nighthawk app and click on Parental Controls.
The second one is I access the Circle app directly.
In both cases, I don't see the menu at all nor the passcode. It claims to have sent it except I'm not sure which number it went to.
Please help.
Thanks!
Netgear1
Netgear2
- Christian_RMar 25, 2020NETGEAR Employee Retired
Hi speedster99,
Thanks for getting back. I have sent you a message.
Christian
