speedster99
Mar 21, 2020Aspirant
Nighthawk - Circle
Hi, Enabled Parental Controls on the router admin page. It directed me to install Circle 1st Gen app on Android which I complied with. The app says 'We found circle'. Clicked on Manage Circle. Chos...
Christian_R
Mar 27, 2020NETGEAR Employee Retired
Hi speedster99,
May you provide me with a screenshot from your end when viewing my private message. Furthermore, you may provide me with your serial number in the meantime and I'll have the post edited to remove the sensitive information.
Thanks,
Christian
speedster99
Mar 27, 2020Aspirant
Hi Christian,
A PNG file is attached that shows the window of your private message that doesn't have a Reply button, or at least I couldn't find it.
My router's serial #:
Thanks!
- speedster99Mar 31, 2020Aspirant
Thanks so much, Christian, for solving my issue by emailing the PIN. I appreciate your help very much!
