JuiceDude's avatar
JuiceDude
Apprentice
Aug 13, 2025
Nighthawk AC4000 Router (R8000P)
hi there
I have been running 1st generation circle on the router for years along with the iOS App.  It has now completely stopped not working.
I went ahead and factory reset the router using all defaults settings and still the same problem.
Profiles not working i.e. any site just shows meet circle webpage
Cannot get Text Code to use on another device.
Cannot get Passcode to use on another device
Does not work when I am connected to my mobile network.
I am running the latest version of the firmware V1.4.4.94_1.3.56
Thanks
  • hi there
    Thanks
  • FURRYe38's avatar
    1st Generation Circle was depreciated a while ago. I presume final end came to you after subscription may have ran out.
    There is newer generation Smart Parental Controls that is for subscription: https://kb.netgear.com/000062109/How-do-I-set-up-and-install-NETGEAR-Smart-Parental-Controls
    However I see the SPC is not supported on your model router: https://kb.netgear.com/000064166
    So you may need to upgrade your router to something newer generation that is supported by SPC if you wish to use this feature.
