bLampert
Apr 22, 2018Aspirant
Nighthawk X6 R7900 - How to schedule blocking internet for kids computers.
Just bought this router the other day. My previous Asus router had the ability to turn off internet access per device on a set schedule. I was able to turn off the internet for my kids computers ever...
microchip8
Apr 22, 2018Master
Go to Advanced -> Security -> Block Services and use port 1 - 65535 for the IP you need to block
In Advanced -> Security -> Schedule you can set when to block
bLampert
Which port number do I need to input?
- microchip8Apr 22, 2018Master
if you want to really block everything, then all ports from 1 to 65535
- bLampertApr 22, 2018Aspirant
Ok I think i have it figured out but it seems like I can only set only one schedule for devices. Is there a way to set more than one schedule? Like I usually had the kids PC's internet shut off at 10PM Monday-Thursday, then for them to shut off at 12AM Friday & Saturday.
- michaelkenwardApr 23, 2018Guru - Experienced User
Also investigate Parental Controls.
There is a manual for the R7900 somewhere at the end of this link:
>>>> R7900 | Product | Support | NETGEAR <<<<
See page 54.
