Grrrrrrr
May 27, 2024Aspirant
Orbi app trusted devices and phone numbers
I can't see how to set/reset my Orbi trusted devices and phone number I go to Account Management --> Login Settings-->Two-step Verification I used to have 2 trusted devices. But no idea what th...
May 28, 2024Guru - Experienced User
Grrrrrrr
May 28, 2024Aspirant
Thanks. Sadly doesn’t work. The help on how to reset circle states I should open the Circle app then go to the hamburger menu. When I open the app, I am forced to enter a passcode from sms to start - I can’t get to the menu. I can only see 4 screens siding with as attached. Any ideas?
- FURRYe38May 28, 2024Guru - Experienced User
You'll need to contact NG support for help with this.
