dbwiddis
Mar 23, 2020Star
Orbi RBR50 + Circle frequent DNS failures
I've spent the better part of the past two weeks troubleshooting some DNS issues. They are similar to those reported recently here and probably here and related to similar reports as long as a year ...
- Mar 23, 2020
I've already given up trying to get Orbi to function as a proper Router + Disney + Armor, because it's nothing but trouble. To get Orbi to a stable state, I have to disable practically everything that I could disable, including its internal DNS and DHCP client. I'm currently keeping Orbi for its WiFi capability and delegate all other router functions to DIY pfSense Router Firewall.
I went through a similar pain before I settled on the current setup, which has been holding up quite well during Stay-At-Home order.
- SB8200 -> pfSense -> Orbi AP Mode with static DNS servers and IP address
I settled on pfSense because I need a reliable Gigabit Router with enterprise class DNS resolver, DHCP, Firewall, DNS Filtering, VPN, plus a whole bunch of other features that I don't really need. If you're comfortable with installing pfSense, it's worth a shot.
dbwiddis
Mar 23, 2020Star
Thanks... pfSense looks like a great solution but my head's spinning with all the hardware options and compatibility requirements. What hardware will support 1G speeds?
SW_
Mar 23, 2020Prodigy
Just an Intel Ethernet card and an old PC (4GB RAM, ~3Ghz CPU). The most important is to get the supported pfSense card, Intel Ethernet Adapter I340-T4, which I purchased on Amazon for $40. That's it.
