dbwiddis
Mar 23, 2020Star
Orbi RBR50 + Circle frequent DNS failures
I've spent the better part of the past two weeks troubleshooting some DNS issues. They are similar to those reported recently here and probably here and related to similar reports as long as a year ...
- Mar 23, 2020
I've already given up trying to get Orbi to function as a proper Router + Disney + Armor, because it's nothing but trouble. To get Orbi to a stable state, I have to disable practically everything that I could disable, including its internal DNS and DHCP client. I'm currently keeping Orbi for its WiFi capability and delegate all other router functions to DIY pfSense Router Firewall.
I went through a similar pain before I settled on the current setup, which has been holding up quite well during Stay-At-Home order.
- SB8200 -> pfSense -> Orbi AP Mode with static DNS servers and IP address
I settled on pfSense because I need a reliable Gigabit Router with enterprise class DNS resolver, DHCP, Firewall, DNS Filtering, VPN, plus a whole bunch of other features that I don't really need. If you're comfortable with installing pfSense, it's worth a shot.
SW_
Apr 05, 2020Prodigy
Shahab, I shared your frustration because I had been through that rollercoaster rides. If you have an old router lying around, dust it off and switch Orbi to AP mode, decouple Orbi from routing chores. You could switch it back once this lockdown/COVID-19 ordeal is over.
Shahab
Apr 07, 2020Apprentice
My issues have changed ever since I got the replacement Orbi router and didn't enable Circle. Multiple times a day my connection will drop all together. Every day I call Netgear support and ask for my ticket to be escalated to Level 2 support and I just have the Level 1 guys make incremental changes to a setting or 2 which don't end up making any difference. Yesterday, they had me call Charter and ask them to reset my cable modem/clear the IP pool to address the DoS/Ack scans showing up in the logs, after the reset, don't see those entries anymore.
Some of the changes made yesterday:
Changed MTU size to 1472 from 1500
Enabled IPv6, set to Auto
Previous changes:
Disable SIP ALG
Disable Port Scan and DoS Protection
I really hate to spend money to go out and buy a new router, but it seems that's the best option at this time. Any ideas on how to escalate to higher level support @ Netgear?
- FURRYe38Apr 07, 2020Guru - Experienced User
So when this happens do you see the top ring LED on the RBR turn PINK?
Do both wired and wireless connections stop at the same time when this happens?
IPv6 should be disabled if you don't have native IPv6 support from your ISP.
SIP ALG should be enabled.
Be sure your using good quality LAN cable between the ISP Modem and RBR. CAT 6 is recommended. Swap out.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.Try downgrading the FW to v30 on the RBR as a last resort as well.
All this might be an indication that your ISP modem could be faulty as well. If two different Orbi systems are experiencing the same problem. Something to consider asking the ISP to change out for something newer if possible.
I would post a new post since this thread is in regards to Circle causing problems which seems to be temporarily fixed if users disable Circle. Which you have done and still continue to see problems which seem to point to something else.
Shahab wrote:My issues have changed ever since I got the replacement Orbi router and didn't enable Circle. Multiple times a day my connection will drop all together. Every day I call Netgear support and ask for my ticket to be escalated to Level 2 support and I just have the Level 1 guys make incremental changes to a setting or 2 which don't end up making any difference. Yesterday, they had me call Charter and ask them to reset my cable modem/clear the IP pool to address the DoS/Ack scans showing up in the logs, after the reset, don't see those entries anymore.
Enabled IPv6, set to AutoPrevious changes:
Disable SIP ALG
