dbwiddis
Mar 23, 2020Star
Orbi RBR50 + Circle frequent DNS failures
I've spent the better part of the past two weeks troubleshooting some DNS issues. They are similar to those reported recently here and probably here and related to similar reports as long as a year ...
- Mar 23, 2020
I've already given up trying to get Orbi to function as a proper Router + Disney + Armor, because it's nothing but trouble. To get Orbi to a stable state, I have to disable practically everything that I could disable, including its internal DNS and DHCP client. I'm currently keeping Orbi for its WiFi capability and delegate all other router functions to DIY pfSense Router Firewall.
I went through a similar pain before I settled on the current setup, which has been holding up quite well during Stay-At-Home order.
- SB8200 -> pfSense -> Orbi AP Mode with static DNS servers and IP address
I settled on pfSense because I need a reliable Gigabit Router with enterprise class DNS resolver, DHCP, Firewall, DNS Filtering, VPN, plus a whole bunch of other features that I don't really need. If you're comfortable with installing pfSense, it's worth a shot.
Shahab
Apr 13, 2020Apprentice
If we use the Orbi as an AP, will it still use the satellites?
dbwiddis
Apr 13, 2020Star
Shahab wrote:If we use the Orbi as an AP, will it still use the satellites?
Yep, that's how mine is configured now. you get all the benefits of the satellites and high speed connectivity throughout your house, but you let another upstream router/firewall handle the firewall/DHCP/DNS stuff. Let the Orbi do what it does best!
- Smge1lcApr 19, 2020Guide
So in the last couple days, I found the orbi routers starting to stall on loading website and access to devices such as fire tv despite having shut down Circle.
So I bit the bullet and upgraded the firmware to the Voxel mod firmware.
I will keep you informed on issues or stability.
- ShahabApr 19, 2020Apprentice
Netgear finally came back and said that there was an issue with my satellites and they gave me a beta firmware to update the satellites to. Will see how it works out.
Shahab
- FURRYe38Apr 20, 2020Guru - Experienced User
There is newer relase FW available as well:
https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16
Let us know how it goes for you. If you continue to see problems, keep in touch with NG support.
Shahab wrote:Netgear finally came back and said that there was an issue with my satellites and they gave me a beta firmware to update the satellites to. Will see how it works out.
Shahab
Let us know how it goes.
Smge1lc wrote:So in the last couple days, I found the orbi routers starting to stall on loading website and access to devices such as fire tv despite having shut down Circle.
