mom8693
Aug 23, 2020Follower
Orbi RBR750 compatible with Circle 1st generation?
Can anyone tell me if the ORBI RBR750 mesh sytem is compatible with Circle 1st Generation? Circle says it's compatible with ORBI, but doesn't specify particular routers. I'm trying to install it, bu...
Aug 23, 2020Guru - Experienced User
NG hasn't implemented Circle yes on Orbi AX. One moderator said it was on the list. No time frame when though.
Also be sure to post about any Circle questions for information in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
