csilveira
May 05, 2020Tutor
Orbi WiFi 6 no parental controls
So I am really surprised and honestly upset that the new WiFi 6 orbi does not have any parental controls whatsoever even though the website clearly states that it does. Is this a short sided mistake t...
May 05, 2020Guru - Experienced User
Orbi AX does support Access Controls so I wouldn't say there is "no parental controls" on Orbi AX:
You'll need to post in the Circle forum to inquire about Circle:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Or contact NG about CIrcle support on Orbi AX.
https://www.netgear.com/support/product/circle.aspx
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Good Luck.
csilveira wrote:
So I am really surprised and honestly upset that the new WiFi 6 orbi does not have any parental controls whatsoever even though the website clearly states that it does. Is this a short sided mistake that will be corrected or what? If there are no parental controls like circle coming I will be returning.
Since the website states that parental controls are included I feel like I was misled in this purchase. I hope someone from Netgear has a good response and not some inane “here are the devices that support circle” link. The product description states parental controls so when are they coming?
- FURRYe38May 05, 2020Guru - Experienced User
You may want to look in to this as an alternative solution in mean time:
- csilveiraMay 06, 2020Tutor
Thanks for that. However, is there a timeline for parental controls on the Orbi 6? My current Orbi supports Circle, and I hoped that the new Orbi did as well. The website says the new Orbi supports parental controls so I expected that to be true.
If I have a timeline to look to maybe I will not return it. But if not then I will keep my current setup and return the new one with some amount of prejudice.
- FURRYe38May 06, 2020Guru - Experienced User
NG doesn't make known of any timelines, if or when new features are forthcoming to Orib systems. Thus we don't have any information regarding this.
There is Accessl Controls for now for Orbi AX.
