drdoz
Jul 21, 2018Apprentice
Orbi/Circle and Apple TV
When I have Circle enabled, my Apple TV becomes unusable. Almost none of the apps work (netflix, bbc, even the app store). I have the device marked as "unmanaged," and yet Circle is still apparently ...
- Jul 22, 2018Thanks for the reply. Both issues are resolved. After several restarts of both devices, Circle finally stopped managing the Apple TV. I found that the layer3 device actually had 2 connections (one cryptically named) and I needed to unmanage both.
DexterJB
Jul 22, 2018NETGEAR Moderator
Hi drdoz,
Welcome to the community!
1. Are the same services (Netflix, BBC, App Store) functioning on another unmanaged device?
2. Have you tried setting a filter level (Adult) for the Apple TV and check if the issue will persist?
Dexter
Community Team
- drdozJul 22, 2018ApprenticeThanks for the reply. Both issues are resolved. After several restarts of both devices, Circle finally stopped managing the Apple TV. I found that the layer3 device actually had 2 connections (one cryptically named) and I needed to unmanage both.
