AlexBralex12
Dec 11, 2019Follower
Parental control on guest network?
Greetings to the community!
I am looking for a wifi router that supports creating a second network with the parent control enabled.
I need to restrict the time for the whole second network (not based on the MAC addresses).
Could you please tell if it possible with the NETGEAR wifi routers?
If yes, what is the model to look at?
Thanks much!
Hi AlexBralex12, welcome to the community! You may want to check out the Circle feature for the supported models. You can learn more on the links below.
https://kb.netgear.com/000038874/Why-should-I-enable-Circle-on-my-NETGEAR-router
https://kb.netgear.com/000038873/What-is-Circle-and-why-should-I-use-it-with-my-NETGEAR-router
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Dexter
1 Reply
- DexterJBNETGEAR Moderator
Dexter
