OrbisUser95
Oct 08, 2020Aspirant
Parental Controls - Orbi
Trying to figure out which model of Orbi to buy. I want the strong parental controls that are availbale via the Circle App. However, the top line Orbi systems don't have Circle. Are the parental controls as good as Circle in the high speed wifi 6 tri-band systems? AX4200 and higher models for example.
Circle has not been featured yet on Orbi AX. Circle is supported currently on Orbi AC models.
For help and information about Circle, please post in the circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/support/product/circle.aspx
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-DisneyGood Luck.
Returning my AX4200 mesh system. There are no parental controls despite misleading advertising.
