michaelm8718
Jan 09, 2021Guide
Parental Controls missing on RBR850
I have seen other threads on this but I thought by now the features of Parental Controls will be available via Circle. I live in the UK and just installed my new ORBI AX6000 system today with 2 satell...
Aug 13, 2021Guru - Experienced User
So ethernet ports on RBS become non functional after they were updated? Did you factory reset the RBS after the FW update?
Ok the downgrade of the RBR is a known. Same thing for 7 series as well.
ekhalil wrote:
FURRYe38 wrote:
Just curious, are you able to downgrade back to v3 by chance?
No, The satellites are ok to downgrade to v3, but I could not downgrade the router to v3.
ekhalil
Aug 13, 2021Master
FURRYe38 wrote:So ethernet ports on RBS become non functional after they were updated? Did you factory reset the RBS after the FW update?
No, Ethernet ports are ok.
The problem is in the Router that can't recognize the wired satellites. Wired satellites can be added, but after restart they get permanently disconnected.
Factory resetting the satellites did not help.
- FURRYe38Aug 13, 2021Guru - Experienced User
Ok. I'll pass this on to NG for review. I'm kinda dreading updating to this version as my RBS are ethernet connected. :smileyembarrassed:
- ekhalilAug 13, 2021Master
FURRYe38 wrote:Ok. I'll pass this on to NG for review. I'm kinda dreading updating to this version as my RBS are ethernet connected. :smileyembarrassed:
Then don't upgrade to this software. I had to disconnect Ethernet on my 2 Satellites and use wireless backhaul instead.
Looking forward for a fix from Netgear.
Ok well, I'm a beta testers so I may have to udpate.
Any chance we could get some debug logs from you if they need some logging?
Are your RBS directly connected to the RBR or are there any LAN switches in between? If so, can you give brand and model#...
ekhalil wrote:
Then don't upgrade to this software. I had to disconnect my 2 Satellites and use wireless backhaul instead.
