michaelm8718
Jan 10, 2021Guide
Parental Controls missing on RBR850
I have seen other threads on this but I thought by now the features of Parental Controls will be available via Circle. I live in the UK and just installed my new ORBI AX6000 system today with 2 satell...
ekhalil
Aug 13, 2021Master
FURRYe38 wrote:....
Any chance we could get some debug logs from you if they need some logging?
Sure!
FURRYe38 wrote:.....
Are your RBS directly connected to the RBR or are there any LAN switches in between? If so, can you give brand and model#...
I have direct cables from Router to the Satellites.
Aug 13, 2021Guru - Experienced User
Ok good. Thanks for the info. I'll see what they need if anything. Hate to see that feature be broken. :smileyfrustrated:
