lucliu
Aug 16, 2022Aspirant
Parental controls on C7000v2
Hello all, The C7000v2 cable modem I bought myself worked fine with the Parent Controls, and my service provider is Comcast. Recently it started to not. So I used the NETGEAR genie application to...
michaelkenward
Aug 17, 2022Guru - Experienced User
Which parental controls?
There are various types of parental controls with their own sections in this community.
Circle Smart Parental Controls - NETGEAR Communities
or
NETGEAR Smart Home Parental Controls - NETGEAR Communities
Which products support NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
Other devices support Circle:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Circle also needs a subscription.
Open DNS backed out of the Netgear collaboration on free parental controls some time ago.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
Netgear now offers various subscriptions for parental controls.
Other devices support Circle, another subscription service. But that too seems to be a moveable feast:
There may be more recent stuff out there. It is hard to keep up.
What is Live Parental Controls? | Answer | NETGEAR Support
Is there a way to downgrade the firmware ...
No.
lucliu
Aug 30, 2022Aspirant
Currently I configured with OpenDNS nameservers on C7000v2 for parents controls. Its service is OK, but you can't configure with specific time intervals.
- michaelkenwardAug 30, 2022Guru - Experienced User
That's what happens when you have combined modem/router. It is never going to be as versatile, or kept up to date, as a modem followed by a stand-alone router.
In effect you are using the latest incarnation of the old free parental controls. Anything else needs a subscription.
- lucliuSep 01, 2022Aspirant
What are the parents control options for Netgear C7000v2? Even with the subscription?
Or get a different cable modem/router that can do more?
Thanks.
- michaelkenwardSep 01, 2022Guru - Experienced User
Try asking the people who use it:
And the people who use this modem/router.
What do you want to achieve with parental controls?
